![]() | Home > Technical > Battery Options |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Hi,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
No problem replacing your "wet battery" with a stop/start AGM, not sure how much difference the stop/start aspect will really make, had a Varta G14 (019) stop/start AGM on mine for 5 years and never had a flat battery or fail to star albeit a MY13 S/C, main consideration would probably be extra cost for the AGM.
Thank you Col. |
Thanks @RRSTDV8. I never let the battery get too low and I have a Ring RSC612 SmartCharge Premium Plus charger. I'd like to have a decent trickle charger or a solar charger but from what I've been told previously these shouldn't be connected permanently to the battery - and my 2005 doesn't have separate / isolated terminals. Maybe you could confirm or correct if that's not the case.
Gandalf Member Since: 11 Sep 2017 Location: South Killingholme Lincolnshire Posts: 205 ![]() ![]() ![]() |
I've got a lidl ultimate speed charger i've had for years in what was my garage, then a cable running to a 12s socket and flying lead to the car via that 12s socket. Works brilliantly, only use the car 2/3 times a week on short trips. If it ain't broken down it soon will
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 474 ![]() ![]() |
Hello All,
RugHead Member Since: 26 Nov 2020 Location: South Yorkshire Posts: 40 ![]() ![]() ![]() |
https://batterygroup.co.uk/batteries-by-ap...-stop?c=18
Thank you very much.. ===========================================
