Home > Maintenance & Modifications > blanking egr?
alexgmx
United Kingdom 2007 Range Rover Sport TDV8 HSE Tonga Green
blanking egr?
hi everyone
i have read that blanking the egr could speed up the car a bit but have also read that it could lead to knocking noises on the engine. has anyone else attemtped this mod and any recs for me?
also want to mention that she is blowing out black smoke above 2000 rpm and an engine fault light came on shortly before on a long trip down to to the continent. shes still down there and want to take either a new MAF sensor or an egr blank kit if that would fix the issue as well but haven't been able to check the computer to see what the issue is.
any help is highly appreciated
alex
l320 rrs tonga green 3.6 v8 diesel.
Post #606060 Thu Oct 29 2020 9:22pm
Wmckeown09
Hello had similar issues recently and first LR specialist said I needed a new DPF at considerable cost but still had same issue. Took to another LR specialist and it was the MAF sensors and now running great.
Post #606061 Thu Oct 29 2020 9:30pm
Black smoke above 2000rpm could be a simple split intercooler hose or it could be one of several other things.
As for EGR blanking, on the TDV8 it will need a map doing too in order to ensure you don't get issues with engine lights coming on etc. Blanking the EGR is really more about removing it as a future failure point, and much done with the 2.7TDV6 which did have EGR reliability issues. The TDV8's EGRs are much less prone to problems for some reason. Certainly they can do 150k miles or more without an issue. 2012 SDV6 - it's missing a couple of cylinders
Post #606068 Thu Oct 29 2020 9:58pm
alexgmx
cheers everyone
Post #606088 Fri Oct 30 2020 2:27pm
slinkyjynx
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Santorini Black
Just remember it's a motoring offence in the UK to do such a thing. If it's undiscovered then it's no problem but it'll likely invalidate your insurance as well.
Post #606789 Thu Nov 19 2020 6:44pm
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
Had black smoke from my 2005 TDV6 a few years ago, checked the 3 hoses (seems to be the usual problem) but the fault turned out to be a crack in the intercooler itself. Part replaced, running great ever since.
Post #606804 Thu Nov 19 2020 9:12pm
IronDuke50
United Kingdom 2013 Range Rover Sport 4.4 V8 Autobiography Firenze Red
gone
Post #608146 Mon Jan 04 2021 3:01pm
