Home > General > Grumbling Under Load
Pufftmw
Coming back down the M4 today and noticed that there was a rumbling vibration when accelerating, even slowly but nothing when foot off the accelerator. Rumbling seemed to get worse the more I was trying to accelerate. Car also seems a bit sluggish but that might just be me not wanting to push it whilst its rumbling.
Rear d/shaft seal is leaking but we checked the diff and that seems ok.
Any pointers?
Post #605749 Mon Oct 19 2020 7:57pm
Torque converter ? 2012 SDV6 - it's missing a couple of cylinders
Post #605752 Mon Oct 19 2020 9:09pm
Stevepd
Front diff? 2006 2.7 TDV6 HSE in Cairns Blue.
Post #605758 Tue Oct 20 2020 7:12am
Pufftmw
Hoping its not the torque converter Big Cry Any idea on cost of replacement?
Post #605765 Tue Oct 20 2020 10:27am
Eskimo
Check both front driveshafts, had a similar issue with my Sport the other week.
Couldn't locate the noise so took it a local indie (MM4x4) to get it looked at. About an hour after I dropped it off I got a call to say the nearside front inner cv joint was trashed and a little bit of play in the wheel bearing too.
1 driveshaft and wheel bearing later the rumble has gone as has the loud clunk which occasionally happened on up/down shifts. It would appear that the only thing that was holding it together was the CV boot Shocked Shocked Shocked Shocked 2006 RRS HSE 2.7 TDV6 (The Baby one as I keep being told)
1999 Discovery 4.0 V8 (Gone but not forgotten)
1997 Range Rover 3.5 V8 (Long gone now)
1966 Series II SWB with RR 3.5 V8 (Never finished, now sold)
Post #605791 Tue Oct 20 2020 9:41pm
1richard1
Try the manual shift find a decent hill then accelerate through the gears, does it only happen under load and in certain gears, if you ease up of the accelerator does the noise go and does it happen in only certain gear ranges?
Post #605796 Tue Oct 20 2020 10:11pm
Pufftmw
Found a hill (all hills are decent where I live!) and gave it the beans through the gears. Nice smooth road too.
Grumbling/vibration not apparent up to NSL but there was a bit of a bang when I lifted my foot off the accelerator sharply. So possibly more d/shaft/diff/prop shaft/cv joint related?
Into the garage tomorrow for leaking rear d/shaft, rear arb hanger things, a couple of punctures (yes not only you HWN!) and whatever this is.
Thinking about it, there's also a knock when you put it in reverse and steer at the same time, so possibly CV joint.
Post #605844 Thu Oct 22 2020 8:36am
Eskimo
Sounds very similar to mine. Ended up costing £450 all in so not too bad. Could've saved a bit not doing the wheel bearing, but as it was all apart it was only the extra for the part.
Good luck tomorrow, hope you can get it sorted. 2006 RRS HSE 2.7 TDV6 (The Baby one as I keep being told)
Post #605865 Thu Oct 22 2020 8:58pm
Stevepd
I’ve got a slight thump on/off the throttle and it’s been diagnosed as a little slack in the chain of the transfer box. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #605887 Fri Oct 23 2020 1:38pm
