Home > In Car Electronics > No reversing camera or parking sensors
Page 2 of 3 <123>
Brit Plumber
The CAN is a controller area network. It’s a network that connects many modules together for quicker and common communication. Although the camera doesn’t have a direct CAN connection, the reverse signal on the car tells the screen to switch to video. The Parking Aid receives speed signals and also broadcasts signals back for obstacles etc. As you can see in your photo, the camera is sending a corrupt signal so everything is working but the camera is corrupt. I really have no idea why both have failed together as they should bring each other down.
The CAN isn’t switching the screen to the reverse image which is corrupt. It’s as if the reverse selection isn’t being activated. Can you turn on the parking aid manually? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #606055 Thu Oct 29 2020 8:26pm
Silverstone
United Kingdom 2012 Range Rover Sport Supercharged HSE Baltic Blue
Have just tried pressing the parking aid button in the dash. This flashes six times and stays off - this result is the same both in Reverse and Drive (I hoped in Drive it might at least activate successfully the front sensors). There is no replacement for displacement - W O Bentley
MY2013 5.0 Supercharged HSE L320
Post #606056 Thu Oct 29 2020 8:42pm
Brit Plumber
I think that 6 flashes is a fault code. 2019 5.0 SC SVA (Current)
Post #606057 Thu Oct 29 2020 8:55pm
Silverstone
Wow! Useful! Any idea where I can look this up?
BTW - just reading this old link after searching on Google for “flashing of L320 parking aid button”:
https://www.rrsport.co.uk/forum/topic45684-15.html
Does the comments on page 2 of 4th Feb 2017 have any relevance?
It said:
“Just thought I'd post and draw a line under this fault, to possibly help someone else.
I got hold of a local guy who specialises in LR diagnostics, but he only came up with the same fault code that I already had.
He checked on Topix and emailed LR for me and they narrowed it down to 3 possible faults
1. Wiring harness continuity between the Module and the switch
2. Switch fault
3. Module fault
Checked the continuity all ok
Bought a new switch panel and fitted that, fault still there. Bought a new Module and reset, all working again.
So there you go, a new Module at a cost of �128 + vat and it's all good again. “
Also there was also the feedback of 1st June 2020 on that same thread. Does this have any relevance?
“I know this an old post but I had this display shown on a car I bought. I tracked it down to a bad parking sensor on the front bumper. Apparently any faulty sensor front or back will stop the camera working. I also noticed that as my battery ran down while messing with the car with the ignition on it stopped working again although the parking warnings were still working which they weren't initially. As soon as I drove the car and got the battery charged up it started working again, so it is quite voltage sensitive.”
Finally, what can cause the corruption of the camera feed itself as shown in my photo this evening?
Kind regards
Silverstone There is no replacement for displacement - W O Bentley
Post #606058 Thu Oct 29 2020 9:21pm
Brit Plumber
So the manual says if it flashes when active there is a fault in the sensors, soundest, wiring or module. 2019 5.0 SC SVA (Current)
Post #606059 Thu Oct 29 2020 9:21pm
Silverstone
Brilliant! I’ll give your info to Loughrans next week. How about the corrupted camera signal please? There is no replacement for displacement - W O Bentley
Post #606062 Thu Oct 29 2020 9:32pm
Brit Plumber
When you tested the dash switch, we’re you in Park? 2019 5.0 SC SVA (Current)
Post #606063 Thu Oct 29 2020 9:37pm
This mentions flashing LED's
Post #606064 Thu Oct 29 2020 9:39pm
Brit Plumber
Not sure on the camera signal other than the camera being goosed. Wait until the bitter end before trying to replace the camera as it’s not cheap. It should still display though, even if corrupt. When you select reverse, I take it nothing happens on the screen at all. It just stays on the screen it’s been on? 2019 5.0 SC SVA (Current)
Post #606065 Thu Oct 29 2020 9:40pm
Silverstone
In Park the dash switch will not flash at all either on its own or if pressed manually. In Reverse it flashes six times as you select R (no pressing of button required). In Drive it only flashes - six times - when you press the dash button. There is no replacement for displacement - W O Bentley
Post #606066 Thu Oct 29 2020 9:45pm
Silverstone
Brit and Col - thanks again to you both on this.
When I select reverse the "Parking Aid Alert - Camera Unavailable" briefly appears on the Home Screen (as last screen in use) and the disappears, just leaving me with the original Home Screen again. There is no replacement for displacement - W O Bentley
Post #606067 Thu Oct 29 2020 9:54pm
Do you know what the actual fault code numbers are at all? as I guess you don't have the Gap diag. tool or you would have mentioned it.
Post #606069 Thu Oct 29 2020 10:17pm
Silverstone
Hi Col - I'd struggle to wire a three pin plug so no code reader (I'd be dangerous with it!) However at Loughrans when they had a quick initial look with a code reader. I think the technician said the code was the image processing module. I can't say for certain if there were other codes too or not - that was the only one mentioned. There is no replacement for displacement - W O Bentley
Post #606070 Thu Oct 29 2020 10:22pm
Unfortunately there are over 40 separate codes listed for the parking sensors so difficult to tie down without actual number, when I have more time I will have a read through and see if any mention image module. I did see this one, but don't know if it is relevant at all though.
Post #606071 Thu Oct 29 2020 10:38pm
Silverstone
Thanks Col! Didn't think to ask the technician for the exact code as I naively thought there would only be one code for this. Now realising how complex this all is!! There is no replacement for displacement - W O Bentley
Post #606072 Thu Oct 29 2020 10:42pm
Page 2 of 3 <123>
