![]() | Home > In Car Electronics > No reversing camera or parking sensors |
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 ![]() ![]() ![]() |
Have just tried pressing the parking aid button in the dash. This flashes six times and stays off - this result is the same both in Reverse and Drive (I hoped in Drive it might at least activate successfully the front sensors). There is no replacement for displacement - W O Bentley
I think that 6 flashes is a fault code. 2019 5.0 SC SVA (Current)
Wow! Useful! Any idea where I can look this up?
So the manual says if it flashes when active there is a fault in the sensors, soundest, wiring or module. 2019 5.0 SC SVA (Current)
Brilliant! I’ll give your info to Loughrans next week. How about the corrupted camera signal please? There is no replacement for displacement - W O Bentley
When you tested the dash switch, we’re you in Park? 2019 5.0 SC SVA (Current)
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
This mentions flashing LED's
Cheers Col |
Not sure on the camera signal other than the camera being goosed. Wait until the bitter end before trying to replace the camera as it’s not cheap. It should still display though, even if corrupt. When you select reverse, I take it nothing happens on the screen at all. It just stays on the screen it’s been on? 2019 5.0 SC SVA (Current)
In Park the dash switch will not flash at all either on its own or if pressed manually. In Reverse it flashes six times as you select R (no pressing of button required). In Drive it only flashes - six times - when you press the dash button. There is no replacement for displacement - W O Bentley
Brit and Col - thanks again to you both on this.
Do you know what the actual fault code numbers are at all? as I guess you don't have the Gap diag. tool or you would have mentioned it.
Hi Col - I'd struggle to wire a three pin plug so no code reader (I'd be dangerous with it!) However at Loughrans when they had a quick initial look with a code reader. I think the technician said the code was the image processing module. I can't say for certain if there were other codes too or not - that was the only one mentioned. There is no replacement for displacement - W O Bentley
Unfortunately there are over 40 separate codes listed for the parking sensors so difficult to tie down without actual number, when I have more time I will have a read through and see if any mention image module. I did see this one, but don't know if it is relevant at all though.
Cheers Col |
Thanks Col! Didn't think to ask the technician for the exact code as I naively thought there would only be one code for this. Now realising how complex this all is!! There is no replacement for displacement - W O Bentley
