Home > Technical > Battery
OB42UK
United Kingdom 2013 Range Rover Sport SDV6 SE Baltic Blue
Battery
Hi all.
Can someone tell me if I disconnect the battery from my RRS 2013 will I have any issues with the radio needing any type of code and so on as I don't have the original book for my car, any help clarifying this subject would be much appreciated.
Thanks in advance
Orlando
RRS 2013 Baltic Blue
Post #605578 Thu Oct 15 2020 2:26pm
Dave B
No issues with my 2010 when I've dis-connected the battery, if that's any help.
Dave 2010 3.6 TDV8 HSE (Gone)
Post #605579 Thu Oct 15 2020 2:31pm
OB42UK
Thanks Dave, all I need is to try to reset the ECU as I got an issue with my tailgate switch but I want to make sure the radio does not need any code or so...
Thanks
Post #605581 Thu Oct 15 2020 2:38pm
RRT
I don't know if this applies to the RRS, but experience with resetting ECUs on Audis, where the battery needed to be disconnected for an extended period of time (30 mins) so residual voltage/current drained out of the system (assume capacitors). I actually disconnected the Audi overnight. MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green)
Post #605587 Thu Oct 15 2020 4:24pm
OB42UK
Thanks RRT, I’m actualy waiting for an answer from a LR dealer so hopefully they’ll back to me.
Post #605588 Thu Oct 15 2020 4:32pm
I think they stopped having radio codes before the year 2000 (approx.)
Post #605591 Thu Oct 15 2020 5:18pm
gogsy1956
I'm with Andy,, I wouldn't be worrying about any radio codes,,, i've had my battery off for 3 days before,, worst I've had to do is reset the date / time etc. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #605594 Thu Oct 15 2020 6:03pm
All you will have to do is reset date on the dash as will default to 2009, reset the window one touch operation, and also sunroof "one touch" closing if you have a sunroof. That's it. Out of curiosity what is your tailgate switch issue.
Post #605600 Thu Oct 15 2020 8:31pm
OB42UK
Hi Col, since I bought the car the tailgate switch never worked so I can only open the boot by fob or button inside the car( dashboard), replaced it for a new one witch should work as soon you connect it but unfortunately still can’t open the boot on the actual switch. I think at this point that could be the ECU still thinking that the switch is faulty and not recognise the new one so I want to try and reset the ECU to factory settings. Any tips would be much appreciated at this point.
Post #605606 Fri Oct 16 2020 5:25am
Probably won't make any difference, but have you tried to reset tailgate opening height to see if it does do anything, manually lift tailgate to full height and press and hold the close button in bottom of tailgate until it beeps, only a thought. I do have wiring diagram of the circuit if it helps.
Post #605607 Fri Oct 16 2020 5:48am
OB42UK
It’s worth to try Col thanks for the tip. Do you think you can send me the diagram so I can find where the wires go and try to see if it’s not broken. Thanks
Post #605610 Fri Oct 16 2020 5:54am
PM me a email address and will send it to you.
Post #605612 Fri Oct 16 2020 6:02am
OB42UK
Hi Colin, received the emai, much appreciated.
Regards
Orlando
Post #605641 Fri Oct 16 2020 3:29pm
No problem. Thumbs Up Have just sent another PDF which may be of some use as you don't have one, put it together during lockdown for something to do so may not be perfect. Hopefully relates to your vehicle.
Post #605654 Fri Oct 16 2020 9:25pm
