Home > Maintenance & Modifications > Brake pad warning light |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
The light came on originally because the ware indicator was worn through and brought on the light. When you replaced the pads you should also have replaced the ware indicator. It’s a plug in sensor And cable on the front near side hub and rear off side hub. No magic switch for these. |
Sat Oct 03 2020 1:01pm |
ratty2828 Member Since: 07 Nov 2018 Location: southampton Posts: 12 |
Thanks Landphill
Sat Oct 03 2020 2:24pm |
