Home > Maintenance & Modifications > Brake pad warning light
ratty2828
England 2007 Range Rover Sport TDV8 HSE Java Black
Hello Guys
Need a bit of help,,, I changed the brake pads on my RRsport the warning light has stayed on any ideas on how to reset it
Thanks in advance
Post #605162 Sat Oct 03 2020 12:54pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
The light came on originally because the ware indicator was worn through and brought on the light. When you replaced the pads you should also have replaced the ware indicator. It’s a plug in sensor And cable on the front near side hub and rear off side hub. No magic switch for these.
Post #605163 Sat Oct 03 2020 1:01pm
ratty2828
Thanks Landphill
I replaced the front sensor but not the one at the rear I will get that done asap thanks
Post #605172 Sat Oct 03 2020 2:24pm
