![]() | Home > General (L494) > BROKEN Fiber Optic Cable for Rear Camera L494 2014 |
jaxx Member Since: 13 Jun 2011 Location: Pyrenees Posts: 62 ![]() ![]() ![]() |
Hi,
that sound about right for a JLR dealer, thanks |
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 ![]() ![]() |
On our previous Range Rover the optical loop was faulty.
Flat0ut Member Since: 11 Oct 2014 Location: London Posts: 37 ![]() |
I had the same problem on my RRS. Absolute nightmare for what was a broken connector near the centre console. JLR insisted on replacing the whole wiring loom and tried to get me to pay for it because they said the wiring had been disturbed and broken by me or a previous owner. I got it done under warranty in the end after a lot of arguing. The car had to be pretty much stripped inside to replace the harness. The harness took months to arrive as it had to be specially ordered. |
thats my nightmare, JLR do not have one and cannot give delivery time |
i working just now on Jasons advice with the car Audio shop
Dobby Member Since: 02 Jan 2018 Location: East Seaxe Posts: 102 ![]() ![]() |
Or find a friendly telco engineer, installing cable in a roadside box. He might terminate if for a few pennies. MY15.5 HSE
Here is the Cable JLR changed to repair Broken Fiber Optic wire to rear camber
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
So you managed to get it done under warranty? That's a good result, financially, but having to strip the car and replace the entire loom? Yikes, that's a big job for a dealership. Fingers crossed that they put it back together properly for you. 2012 SDV6 - it's missing a couple of cylinders
