Home > Technical > Temperature Sensor for RRSS 2006
SlipperyKipper
Hello,
I have an issue with my RRS Super charged (2006) where it goes into limp mode, very occasionally. From the code it looks like the temperature sensor has failed and is giving an incorrect temperature to the ECU. The temp gauge does not move from the normal position, but I believe this is to be expected as this is driven from a different sensor.
No warning messages appear on the dash; just the normal "Reduced Engine Performance"
What sensor is it that I need, and does anyone know where it is located?
Fault code is: P0116
Thanks.
Post #604700 Sun Sep 20 2020 4:05pm
I think it’s near the supercharger pulley.
Front top of engine.
Gauge probably doesn’t more as it doesn’t have a better idea of the temp.
Post #604703 Sun Sep 20 2020 4:23pm
Post #604705 Sun Sep 20 2020 4:52pm
SlipperyKipper
Col - Mate thank you for those diagrams! I will pull it apart and give it a check next weekend and get the part ordered.
Post #604711 Sun Sep 20 2020 6:33pm
