Home > General > Tail gate issue
Phil23
United Kingdom 2013 Range Rover Sport SDV6 HSE Java Black
Tail gate issue
Went to open the tailgate earlier, it would only partially open then shut again. I needed it open so forced it, turns out the drivers side strut had come away at the top/body end. Managed to get it back on the ball joint. Is this a common issue?, a DIY fix?. Any help appreciated. Cheers.
Post #604525 Sun Sep 13 2020 9:56pm
Silverstone
United Kingdom 2012 Range Rover Sport Supercharged HSE Baltic Blue
What year is your RRS? There is no replacement for displacement - W O Bentley
MY2013 5.0 Supercharged HSE L320
Post #604528 Sun Sep 13 2020 11:48pm
Any chance the little spring steel retaining clip is broken or missing.
Post #604529 Sun Sep 13 2020 11:51pm
Phil23
Sorry. 2013. Old shape though.
Post #604531 Mon Sep 14 2020 7:31am
Phil23
Could be. I'll have a look later. Haven't opened it since.
Post #604532 Mon Sep 14 2020 7:32am
Silverstone
Had the same with mine last year (MY2013 L320) and ended up having both the struts replaced - along with the small balls that they clip on to. Initially clipped the loose strut back on but it came off a couple of times again - hence replacing the pair. Was worried that a strut would pop off and break the back window.
Note that they are different each side due to the unbalanced weight of the tailgate. There is no replacement for displacement - W O Bentley
Post #604534 Mon Sep 14 2020 8:47am
According to L/R both powered struts are the same, it's the manual one's that are handed, stupid thing is you can buy the ball part separate but doesn't include the retaining clip and it's not listed separate, but that's L/R for you.
Post #604536 Mon Sep 14 2020 9:07am
Silverstone
Thanks Col - I may stand corrected then. Looking at the invoice is does just say 'strut - tailgate Quantity 2'.
Not cheap though - cost £366.90 to get mine fitted a year ago - and that was with family discount at the stealership. There is no replacement for displacement - W O Bentley
Post #604538 Mon Sep 14 2020 10:08am
