Home > Maintenance & Modifications > Red battery urgent
Page 3 of 3 <123
gogsy1956
I'm of the same opinion ad rrstdv8,,, 13V at idle is too low,, that will never charge a 12V battery. 12.2 or thereabouts is bordering on a discharged battery. I would expect to see 14.6 at idle and a fully charged healthy battery around 12.8 at standstill. I would be looking at the alternator first then see how the battery performs afterwards.
I also have a BM2 battery monitor fitted,, an ideal tool if you are trying to monitor the battery in real time. I was a bit dubious a to how accurate it would be but I checked it against my fluke meters and it was spot o 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #604390 Wed Sep 09 2020 5:18pm
Craigb86
Well ive booked in for alternator this morning along with a list of stuff so it would be Ideal if those results point to alternator
Well not Ideal but simple if that makes sense
Post #604391 Wed Sep 09 2020 5:28pm
Bear in mind that a dodgy battery can kill an alternator. Be prepared to replace both but hope only the alternator is required. 2012 SDV6 - it's missing a couple of cylinders
Post #604407 Wed Sep 09 2020 9:38pm
Craigb86
Yea im prepared for that and almost tempted for sake of £150 more for new battery same time then kts warrantied
Post #604408 Wed Sep 09 2020 9:41pm
insiorc wrote:
For folks not too clued up on basic electrics then a cheap little tool can provide good info on what's going on with the battery and charging system without having to figure out a multimeter (yes a multimeter is invaluable in knowledgeable hands). It's a BM2 battery monitor which is left permanently attached to the battery which connects to your phone etc. via blutooth and stores volt data for 28 days. Even for folk familiar with a multimeter this is a handy tool (I've got 27 years experience using them for work)
Dennis, does it matter which side of the BMS module the neg. terminal is connected?
Post #604410 Wed Sep 09 2020 10:01pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Col, I'm not 100% sure what you mean, I fitted the monitor unit inside the battery box and connected to a spare threaded hole on the +ve battery clamp then ran the -ve lead out of the battery box to an earth point just outside. There are red & black coloured fork crimps aleady fitted so I assume is polarity sensitive. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #604418 Thu Sep 10 2020 10:53am
It's not drawing any significant current so I don't think it matters to the car.
the monitor may get a slightly (trivial) more accurate reading connected to the battery
Post #604419 Thu Sep 10 2020 11:06am
Dennis, I assumed the monitor connected direct to pos. and neg. battery terminals, but as on the sport the BMS bolted on the neg. terminal post just wondered if it made a difference as when hardwired a ctek plug in it was recommended the neg. terminal was connected to earth point on the vehicle not the neg. battery terminal, I realise the ctek and the monitor serve two different purposes, but just wondered if it made a difference as would not describe myself as a auto electrician. Laughing However from what you say that is how you wired the monitor in anyway.
Post #604420 Thu Sep 10 2020 11:29am
insiorc
Col, I never thought much about it, I probably would have gone directly across the battery except the -ve was tucked under the scuttle panel area so a pest to get to (probably battery out), I chose the external earth out of lazyness Laughing 13MY Range Rover Sport Autobiography SDV6 - mine
Post #604421 Thu Sep 10 2020 11:33am
insiorc
I'm curious as to why the engine idle volt readings seem to be the focus but not when the engine has higher rev's?
I've not had much dealings with modern so called smart charging, but if a battery is weak then can this not drag a perfectly good alternator voltage down at idle until the battery has more charge, which needs more rev's? It certainly used to be common when checking voltage that it could take a good number of seconds/minutes for the battery voltage to rise to mid 14 volts as the alternator raised the battery volts.
If I was checking my alternator I'd be letting the volts settle after starting, then with meter across the battery I'd be watching/hoping it would rise to about 14.7 ish when rev's were increased (older cars tended to be around 14.4V with rev's). Next test would be with as much load as possible, then the idle volts would likely be lower, but rise to a similar value when engine rev's increased although probably take slightly longer (and take even longer if the battery was knackered) - if this happened I'd consider the alternator likely to be good.
A rough visual indicator of a working alternator is at night with lights on and as much other load on (window heaters, seat heaters etc.) then rev the engine and the lights should get brighter.
From the readings already given, especially when rapidly dropping towards 12V when load turned on and engine idling then I'd be thinking a knackered battery. Did the engine tone change/revs drop when the load was turned on (increased load on engine hints at alternator working harder - so working). I'd suggest repeating your tests but increase engine rev's and see if the volts rise.
Maybe smart charging works different? 13MY Range Rover Sport Autobiography SDV6 - mine
Post #604422 Thu Sep 10 2020 11:38am
Craigb86
Under load it counted down none stop from 13 to 11.9 before i turned it off so it didn't drop too low to cause more damage. As you said I put on high beam and heater to create load and it was losing voltage as fast as counting down would be
Post #604424 Thu Sep 10 2020 2:16pm
insiorc
A good battery should have held that load for a while before dropping to that level, especially if not long since being charged. But it's quite common for a knackered battery to take out the alternator aswell. 13MY Range Rover Sport Autobiography SDV6 - mine
Post #604425 Thu Sep 10 2020 2:20pm
Craigb86
Well alternator is booked in so will get a battery myself and leave it in passenger footwell and say once the alternator is fitted change battery
Cant hurt I suppose to refresh
Post #604426 Thu Sep 10 2020 2:21pm
Page 3 of 3 <123
