Home > In Car Electronics > Reversing camera lines
Guyzer73
Hi All,
So a fair bit on here about reversing cameras and static or dynamic lines, however, nothing about turning them off.
I've got a 2006 NAS Sport with OEM reversing camera fitted in the roof spoiler. Can I turn the lines off within the CCFs?
The reason I want to do this is because the new stereo has dynamic lines which are way better and infinitely adjustable to get just right.
Thanks, have a good weekend.
Post #603589 Sat Aug 22 2020 4:39am
Is the camera a factory fit? as I thought for some reason they only had the "bendy lines" if it had the surround camera system fitted and didn't think that system was an available option on pre-facelift vehicles. If it is a aftermarket camera setup I wouldn't think there is any facility in the CCF to turn any of it off. I do have the surround cameras for what use they are and sure I can turn something off via the dash screen menu but can't remember what, happy to have a look if it is of any use, don't ever recall seeing anything in the CCF files about turning any of it off though.
Just had a quick look, can turn the graphic's on and off using the system setup menu on the touch screen, not sure about earlier cars though.
Post #603590 Sat Aug 22 2020 5:40am
Guyzer73
Thanks Col,
Problem is the OEM stereo and screen are removed and an Android head unit installed. As the unit taps into the on-board system via CANbus and original loom it offers dynamic guide lines.
However I now have both the OEM static lines and the Android dynamic lines showing.
I therefore want to remove the OEM static lines. I'll have a look at the CCFs via my IID Tool.
Any ideas appreciated.
Thanks
Post #603593 Sat Aug 22 2020 8:10am
Some cameras have a loop of wire on the back of it.
Either to flip the camera or
To turn lines off
Post #603594 Sat Aug 22 2020 8:46am
Nothing to change on the back of the o.e. cameras on mine it's all in the touch screen menu, but then again the pre-facelift doesn't actualy have a factory fit reversing camera listed for it.
Post #603595 Sat Aug 22 2020 9:35am
zeb crs
Norway 2007 Range Rover Sport Supercharged Java Black
I see we are going through the same problems here Smile
I have an aftermarket cam in the upper hatch handle with integrated guidelines.
I have several other cameras in the same size so if I can't turn them off I'll change out the camera module.
Post #603596 Sat Aug 22 2020 9:40am
