![]() | Home > Technical > 2013 Sport Power Tailgate |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5061 ![]() ![]() ![]() |
Previously had similar issue, but seemed to be ambient temp related, if it was quite hot it did it occasionally, replaced the external switch between the rear number plate lights and has been fine ever since must be over 4 years now. Could have been pure coincidence as regards to the temp though.
LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336 ![]() ![]() ![]() |
Interesting because I have exact same issue. I had the aftermarket close kit fitted several years ago. But recently the lid unlatches but fails to lift open. However If I push the tailgate closed and try again it always works on the second attempt. Strange that. Could possibly be a sticky release latch. RRS (MY13) Santorini Black SDV6 HSE luxuary
McFarTech Member Since: 13 Sep 2019 Location: Kent Posts: 126 ![]() ![]() ![]() |
The heat issue might hold some truth. I defo think its worse when its a really hot day. ===========================================
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
I dont use mine very often , and noticed it was sticking sometimes
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 552 ![]() ![]() |
Hi,
