Home > Technical > Supercharged Transmission
Craigb86
hi all I'm just listing what could be cause to an issue to try get through
Currently if I set off sometimes it will not go when you put acceleration on it revs like in neutral. On most occasions if you let off gas then let it drop and re press it will go. However some cases I have to go into reverse then drive and it will set off. Once its in and moving I have no issues its the initial setting off. For example setting off on round about or junction or setting off from home and so on.
The garage I went to say it could be a bush and the gearstick might not be fully going into drive.
My question is have you had this happen or know of it for me to look at what might fix it
Thanks as always guys
Post #602669 Sun Aug 02 2020 9:10pm
Yes the bush on the gear selector under the car should be looked at/adjusted/replaced firstly. Which is a relativly easy job.
Other than that, it could be low fluid level particularly if its cold when it happens
Post #602688 Mon Aug 03 2020 11:18am
Might be worth giving something like this try.
https://www.advancedfactors.co.uk/kit500-d...3775-p.asp
Post #602690 Mon Aug 03 2020 11:42am
Craigb86
Thats brill thanks it sounds like the garage i found are really good guys as he suggested that first before i worry.
Thanks for the link as well its an awesome community on here ive been lumbered with a range that needs work but determined to get through it
Post #602691 Mon Aug 03 2020 12:03pm
Oldandconfused
If you want to have a go yourself;
https://www.disco3.co.uk/forum/autobox-gea...2Bselector
When my gear selector went stiff (ooh err missus) I dropped the undertray and soaked the pivot with penetrating fluid, worked the lever a bit then lubricated it with some silicone spray. Been fine for the last 18 months. If you do it yourself, be very careful to follow the correct sequence, a member on here I think, didn't and had to have work done on the gearbox.
Post #602693 Mon Aug 03 2020 12:15pm
Craigb86
Ha this is me being really honest ive come from a subaru that you hit to fix and the range rover is way way out my relm lol I would break it
Post #602694 Mon Aug 03 2020 12:17pm
