Home > In Car Electronics > Pioneer double din radio fitted
hairy
United Kingdom 2009 Range Rover Sport TDV8 HSE Zambezi Silver
Hi hoping someone may be able to help .... Ive fitted a Pioneer double din DAB radio all works perfectly and I have steering wheel controls etc all good, only issue i have is the button on the left side of the steering wheel for making calls doesn't work, is there anyway to get this button to work so I can voice dial? I can press the wee button bottom left of the head unit but would like to have this steering wheel button working as well.
Post #602235 Sun Jul 26 2020 3:15pm
Pufftmw
I would too but I've not heard it done. Does your HU have a facility to allow remote activation/reception of calls? I guess that's a good starting point. The guys are InCarTec are pretty good and I'm sure they'd have sorted it out in their kit if it were possible.
Post #602311 Mon Jul 27 2020 6:29pm
hairy
Hi yes my unit has a button i press and it activates the voice dialling then just speak to it, however it would be nice to be able to use the button on the left side of the steering wheel.
Post #602350 Tue Jul 28 2020 9:26am
map_rrs
Have also just installed a Pioneer DAB/Carplay unit - used the InCarTech kit for it.
When I purchased the kit I asked if the voice command button on the steering wheel would be active and was told it wouldn't.
Suspect there's some factory wiring/CAN stuff that would need to be worked around.
Think you can use "Hey Siri" when an iPhone is connected to the headunit.
Post #602632 Sun Aug 02 2020 8:13am
hairy
Hi yes just fitted the Pioneer double din using the Incar tech kit, and yes i was told button wouldnt work just wondered if anyone had tried to get it to work as I would like mine to work.
There is a small button bottom left of the head unit that I press that activates the voice command and all works perfectly, maybe theres a way to tie in the steering wheel button to this?
all other buttons on steering wheel work ok.
Post #602637 Sun Aug 02 2020 8:52am
