Home > General (L494) > Towing a caravan
dazzerboy
England 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
Towing a caravan
What towing mirrors do people use ive got suck it and see ones at the moment but dont think they are very good cant see much with them more of an hazard than a safety feature lol
Post #601553 Fri Jul 10 2020 7:15pm
IanV8
Scotland
Milenco Grand Aeros with extended arms as I have an 8ft wide van.
Ian 2018 Indus Silver SDV6 Autobiography normally towing a Buccaneer Cruiser.
Post #601560 Sat Jul 11 2020 8:44am
riverblanche
Hi,
I have had the Pyramid rock Steady mirrors for years and have used on a few different cars and they have been fine, I have added an extra elastic strap just in case they do come adrift but all good Thumbs Up
It is a legal requirement to fit mirrors as very few car mirrors comply with ......
There is a legal requirement for you to have mirrors that allow you to see clearly an area that is 4 metres wide from the side of your caravan at a distance 20 metres behind the driver. A caravan is significantly wider than a car even a large 4x4 and you simply can't comply with the law unless you fit towing mirrors.
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #601578 Sat Jul 11 2020 3:54pm
dazzerboy
Thanks ian are they covex or flat glass that you use also would i need the extending arms caravan 7.5ft
Post #601583 Sat Jul 11 2020 5:20pm
IanV8
Scotland
Mine are convex, if you go for the extended ones you can always adjust them in a bit but you can’t adjust the normal ones any further out.
Post #601611 Sun Jul 12 2020 9:34am
GV
Hi, I use Milenco Aeros and they are fine with a standard width caravan. They do need a tighten and an adjust though after a couple of miles as they settle downwards a bit. Just travelled 400 miles with them and no issues. Hope this helps. Thumbs Up
Post #601622 Sun Jul 12 2020 2:10pm
riverblanche
Hi,
they started life as both being convex Rolling Eyes but on a trip up to the Lakes going through Appleby the drivers side one got "kissed" by an oncoming van, I had stopped to let him through as well Big Cry
So now it has a flat glass stick on replacement mirror holding all the bits together and that is fine.
The towing mirror arm is about 240mm then you get the bend for the mirror head, you need about 100mm in the 2 clamps that fit on the car mirrors top edge so you get max 150mm then the mirror, mine are set at about 100mm out so still got some adj left
Towing a Bailey senator
Post #601624 Sun Jul 12 2020 4:50pm
PetesRRS
Australia 2013 Range Rover Sport SDV6 HSE Fuji White
I use Milenco Aero. Have not had any problems with over 25000kms of towing van around Australia including many outback roads
Post #601678 Tue Jul 14 2020 2:05am
