Home > General (L494) > Towing a caravan |
IanV8 Member Since: 06 Jan 2020 Location: Dunfermline Posts: 60 |
Sat Jul 11 2020 8:44am |
Sat Jul 11 2020 3:54pm |
dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212 |
Thanks ian are they covex or flat glass that you use also would i need the extending arms caravan 7.5ft |
Sat Jul 11 2020 5:20pm |
Mine are convex, if you go for the extended ones you can always adjust them in a bit but you can’t adjust the normal ones any further out.
Sun Jul 12 2020 9:34am |
GV Member Since: 23 Jun 2020 Location: Shropshire Posts: 33 |
Hi, I use Milenco Aeros and they are fine with a standard width caravan. They do need a tighten and an adjust though after a couple of miles as they settle downwards a bit. Just travelled 400 miles with them and no issues. Hope this helps. |
Sun Jul 12 2020 2:10pm |
Hi, they started life as both being convex but on a trip up to the Lakes going through Appleby the drivers side one got "kissed" by an oncoming van, I had stopped to let him through as well So now it has a flat glass stick on replacement mirror holding all the bits together and that is fine. The towing mirror arm is about 240mm then you get the bend for the mirror head, you need about 100mm in the 2 clamps that fit on the car mirrors top edge so you get max 150mm then the mirror, mine are set at about 100mm out so still got some adj left Towing a Bailey senator Porsche Cayenne 2022 gone Porsche Cayenne 2020 gone Corris Grey HSE Dynamic 2016 gone Ipanema HSE lux 2010 gone Rimini HSE 2005 !! |
Sun Jul 12 2020 4:50pm |
PetesRRS Member Since: 16 Jul 2015 Location: Melbourne Posts: 29 |
I use Milenco Aero. Have not had any problems with over 25000kms of towing van around Australia including many outback roads |
Tue Jul 14 2020 2:05am |
