Home > Technical > Should this be attached
Craigb86
hey all be gentle still im second day owning a range rover which is going into a garage so I'm trying to find any issues to get done same time
So should this be attached its same both sides
Post #601542 Fri Jul 10 2020 4:29pm
Craigb86
I am genuinly taking all help on board and thank you ive been a subaru guy all my life so this is new territory and you've all been kind
Post #601543 Fri Jul 10 2020 4:31pm
Yes
I would suspect the body has been off as some point.
Post #601545 Fri Jul 10 2020 5:17pm
Craigb86
Its rusted so id say its not been on years whats it to
Post #601546 Fri Jul 10 2020 5:46pm
What year is it?
It helps hold the body on. Or stops it vibrating
Post #601549 Fri Jul 10 2020 6:29pm
Craigb86
Its a 2006 4.2 sc buddy
Post #601551 Fri Jul 10 2020 6:50pm
Craigb86
Is this something i can bolt or is it mechanic job i have impact compressor etc r
Ramps Jacks from restoring the subaru but I keep getting told range rover you can't do trial and error as you cause chaos
Post #601554 Fri Jul 10 2020 8:51pm
Yeah you can.
Just a case of getting the right bolts
Look on here.
www.advancedfactors.co.uk/
There are also some behind the front wheel arches
Post #601556 Fri Jul 10 2020 9:11pm
Tyrefitter
I’m guessing their will be a capped nut on the metal part so you just need a bolt. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #601559 Sat Jul 11 2020 8:23am
I would hazard a guess you have a couple of these missing.
https://www.advancedfactors.co.uk/kyg500311-bolt-976017-p.asp
Post #601563 Sat Jul 11 2020 8:55am
Topsy
Wales 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Forgive me if you already know about the air suspension but if not; read the instruction book before jacking and getting under it. The suspension can drop on you. I used to put the suspension at off road height and leave the boot open.
Post #601564 Sat Jul 11 2020 9:17am
I seem to remember that disconnecting one of the body mount fittings was an LR fix for a noise/vibration issue back in the day. Might be worth having a search to see if you can find further info on it. 2012 SDV6 - it's missing a couple of cylinders
Post #601573 Sat Jul 11 2020 12:18pm
Craigb86
Thanks guys and no I'm 0 knowledge on the suspension thank you very much I will have a read first thats why i thought id come to guys like you im used to working on imprezas which are ancient so this range rover is a whole new world of pain lol the main start after garage is some treatment under the belly as its got start of surface rust so will carry that on thats what made me see those disconnected
But i did get to do a days valeting on it which I enjoyed been years since I've done it it was surprising stress relief it defo didn't come looking this way lol
Post #601598 Sat Jul 11 2020 9:17pm
