Home > Technical > upper screen after head unit install & rear dvd player
mgrover
well the screen sits there with a LR logo. I thought it wouldnt bother me but it does Razz
anyone any ideas what i can do with the sucker? i could try hook up my own amp so i can retain the screen properly but that seems like a lotta work.
also i have the rear dvd player, is there anything i can do to upgrade/remove it? since it won't be used
Post #601461 Thu Jul 09 2020 11:36am
you either need to
1) unplug the display Laughing
2) Fit the rear part of the old head unit behind the dash. There are guides around to show you. And maybe even cable extensions available.
This keeps the display working. should make the rear screens work if fitted, (dunno about sound though)
Post #601462 Thu Jul 09 2020 11:40am
mgrover
1. that would be even worse Razz
2. So i cant make that work with the MOST decoder, because they fight for control of the AMP, and the old HU decides to steal the steering wheel controls events. It would be preferable so my clock would work tbh since i upgraded the IPC to the 2007+ version Razz But i cant see a way of making it work, unless theres a way to tell the old HU to calm its tits on the fibre optic network
Post #601463 Thu Jul 09 2020 11:46am
Oh yes. I forgot you used the RCA to optical converter.
Post #601467 Thu Jul 09 2020 12:54pm
hairy
United Kingdom 2009 Range Rover Sport TDV8 HSE Zambezi Silver
Re: upper screen after head unit install & rear dvd play
you can fit adaptors so that the screen/sat nav/4x4 info all work but you will also need the adaptor for the sound. These can be bought over the net and fitted very easily, ive already done it when I upgraded my stereo to dab etc.
Post #601470 Thu Jul 09 2020 2:46pm
Oh no. Don’t go giving him more ideas Rolling with laughter
Post #601486 Thu Jul 09 2020 7:02pm
hairy
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Post #601493 Thu Jul 09 2020 8:05pm
mgrover
...adapters eh Razz got any links?
Post #601503 Thu Jul 09 2020 10:15pm
hairy
the parts I used I bought from just car kits, if you gone to their website you will find everything you need, all pretty much plug and play. I fitted a Pioneer double din unit with DAB and added a revers camera as well, all fairly easy to do.
part numbers below
navamp to retain audio from original nav. 10-651
bypass cable/steering wheel control interface 20-308
interface with screen retention. 29-712
patch lead 29-025 (to be used with steering wheel controls.
like i said look it up on the net all esay to find.
Post #601522 Fri Jul 10 2020 9:18am
mgrover
ah got all thoseish. its because am using a MOST decoder that i cant use em Sad
Post #601575 Sat Jul 11 2020 4:15pm
