Home > Maintenance & Modifications > Best place to get second key ? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4984 |
what year ?
Sun Jun 28 2020 8:55am |
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 82 |
When I got my 2010 MY RRS a couple of years ago, it only had one key. I think a car with only one key is not a good idea - quite apart from not knowing who's got the other one!
Thu Jul 02 2020 10:52am |
you can get keys from china for ~£25 for a 2007
Thu Jul 02 2020 11:27am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
I did this recently myself. Purchased a key from eBay. Sent it to keysinthepost to have the barrel cut £12, then programmed it with my IID tool 2006 2.7 TDV6 HSE in Cairns Blue. |
Thu Jul 02 2020 4:26pm |
Martyns Member Since: 24 Jun 2020 Location: Farnham Posts: 10 |
Makes me laugh ! But they really can cut a key from a digital photo ! Wow .. I have taken several pics , so will have a good hunt on eBay and send off to get cut , is the iid tool easy to use to program the key ? For a complete novice , I'm assuming its many other uses so perhaps a good investment |
Fri Jul 03 2020 7:50am |
IID tool is probably the most effective thing you can buy for your car. Sell it on when you move on. Buy used for around £325 posted and check the sister sites to. Plenty of help about but ultimately you have to look over the cliff (have a play). Sorry poor analogy 2006 2.7 TDV6 HSE in Cairns Blue. |
Fri Jul 03 2020 10:58am |
each key position has a potential of 3 or 4 options. (from no cutting to all of it cut away), ones you know how the key is designed it's easy to tell from a picture. It is then effectively cut from a code (rather than a worn key)
Fri Jul 03 2020 11:32am |
