Home > Maintenance & Modifications > Best place to get second key ?
Martyns
United Kingdom 2007 Range Rover Sport TDV8 HSE Bonatti Grey
Just purchased my tdv8 and it only came with 1 key, can anyone recommend where to get second key , alternative to the stealers ?
Post #600928 Sun Jun 28 2020 8:26am
what year ?
the first thing to do is to take a clear picture of the key blade,
Should you need to, you can get a replacement blade off ebay (using the pic)
Post #600930 Sun Jun 28 2020 8:55am
Goffy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
When I got my 2010 MY RRS a couple of years ago, it only had one key. I think a car with only one key is not a good idea - quite apart from not knowing who's got the other one!
My Indy got a new key, but then found that the KVM module wouldn't let them program it. They had to fit a new KVM module, so the total cost was abot £420 - all genuine LR parts.
BUT the new KVM module allows me to disable/enable the keyless entry, so from my perspective that was a worthwhile invstement.
Post #601154 Thu Jul 02 2020 10:52am
you can get keys from china for ~£25 for a 2007
A lot of people have had good results.
But the quality of the current supply is unknown. So a gamble.
You would also need a GAP IID to program
Post #601157 Thu Jul 02 2020 11:27am
Stevepd
I did this recently myself. Purchased a key from eBay. Sent it to keysinthepost to have the barrel cut £12, then programmed it with my IID tool Thumbs Up 2006 2.7 TDV6 HSE in Cairns Blue.
Post #601175 Thu Jul 02 2020 4:26pm
Martyns
Makes me laugh ! But they really can cut a key from a digital photo ! Wow .. I have taken several pics , so will have a good hunt on eBay and send off to get cut , is the iid tool easy to use to program the key ? For a complete novice , I'm assuming its many other uses so perhaps a good investment
Post #601196 Fri Jul 03 2020 7:50am
Stevepd
IID tool is probably the most effective thing you can buy for your car. Sell it on when you move on. Buy used for around £325 posted and check the sister sites to. Plenty of help about but ultimately you have to look over the cliff (have a play). Sorry poor analogy Mr. Green 2006 2.7 TDV6 HSE in Cairns Blue.
Post #601211 Fri Jul 03 2020 10:58am
each key position has a potential of 3 or 4 options. (from no cutting to all of it cut away), ones you know how the key is designed it's easy to tell from a picture. It is then effectively cut from a code (rather than a worn key)
The problem I found was that the blade I got from keys in the post did not easily fit the china key. Nothing a file or saw wouldn't sort in my case, but Steve's method avoids this Bow down
Post #601214 Fri Jul 03 2020 11:32am
