Home > Technical > Special Programs Off then Engine System then Transmission
Eaters
Cheers Col Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #599547 Wed Jun 03 2020 7:47am
Eaters
erickwan wrote:
The part where you switch off, re-start and everything is normal until the next hiccup is typical brake light switch.
Symptoms in my case:
"Special programs not available" message - suspension light flags on the dash
"Transmission fault. HDC not available"
Engine will not accelerate beyond 30mph
Switch off and on, everything goes back to normal.
Happens every 1-2 years.
That's a definite update I need to do then. Switch ordered Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #599549 Wed Jun 03 2020 7:57am
Forgot to mention, do not press brake pedal when changing the switch as may well damage the new switch.
Post #599554 Wed Jun 03 2020 8:37am
erickwan
Malaysia
RRSTDV8 wrote:
If you change the brake pedal switch, be careful. There is a procedure involved - do a search as there are some good write ups on here. It's an easy enough job but there's something you mustn't do before it's fitted. Can't remember what but a search will show it.
Yeah. Like don't be tempted to depress or pull the plunger. Just put the switch into the holder, twist and re-install the connector.....and that's it IIRC.
Post #599555 Wed Jun 03 2020 8:46am
Eaters
RRSTDV8 wrote:
Eaters wrote:
Thanks for all the thoughts and suggestions guys. Lets pick up a few of those so that others reading this later may find it useful.
[list]Battery - is about a year old but I'm not ruling it out. I do have a CTEK which I use occasionally if it goes flat (which it has done at least once) including the rejuvenation programme
If it's been flat a couple of times, properly flat, then it might have a weak cell. That will cause problems. I had a battery that lost a cell, my CTEK would run and say "it's charged", put a meter on it and it's 12.7V. Put a load on it and it dropped to <11V.
Sorry RRSTDV8, I missed your reply here in the flurry of others. But thanks for the heads up on the battery. Also note your thoughts about the brake light switch - I guess that's what Col was talking about Robin
Gone:
MGZTT 190 2.5
Post #599556 Wed Jun 03 2020 8:48am
Eaters
Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #599557 Wed Jun 03 2020 8:49am
erickwan
Malaysia
Also Ford, Mazda & LR all use the same switch. For some reason, I find the Mazda lasts a longer on the average.
Post #599558 Wed Jun 03 2020 9:02am
Eaters
Goodness knows which one I've gone for - I've just taken a chance on the cheapest Robin
Gone:
MGZTT 190 2.5
Post #599567 Wed Jun 03 2020 12:36pm
Eaters
I'v just taken the RRS up the road as an initial test - it behaved impeccably!!!
Later on this afternoon I'll take it to my indie. On the phone he asked if I had tried turning off and restarting when the engine fault appeared. I didn't because I was worried it might not start again. But he thought it could be a sticking EGR Valve that caused the initial fault???? But that wouldn't have caused the transmission or suspension faults would it?
Anyway, we'll hopefully see what his code reader says later on. Robin
Gone:
MGZTT 190 2.5
Post #599568 Wed Jun 03 2020 12:41pm
Eaters
OK. Back from the indie. Guess what? Engine fault caused by .....
....split in intercooler hose. Both hoses had just got old and hard and one had given up the ghost. There was a 2 inch split underneath. How the mechanic yesterday didn't see it especially as he actually went round checking the hoses. He must have gone away wondering how he managed to get his gloves so dirty Confused Very Happy
So - car is back and running well again - actually feels a bit nippier - and the strange groaning noise has gone! This may not have cured all the problems but I'll fit the new brake light switch when it arrives. Fingers crossed!
Thanks to all who made suggestions and tips. Thumbs Up Thumbs Up Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #599573 Wed Jun 03 2020 3:04pm
jason-nike
Glad its all hopefully sorted
Post #599585 Wed Jun 03 2020 7:55pm
