![]() | Home > Technical > C1A13 after new compressor |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9030 ![]() ![]() ![]() |
From the manual:
2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
SomersetRRS Member Since: 18 Nov 2019 Location: Somerset Posts: 65 ![]() ![]() ![]() |
Thanks for that. My understanding is that the exhaust valve is integral to the compressor so (I know it's not a 100% solid assumption!) that shouldn't be the cause. That being the case, what's the easiest way to diagnose the exhaust silencer/pipe, reservoir pipes and gallery pipes? Thx. |
So this is driving me a bit nuts... I decided to replace the centre reservoir block as well as I was a bit dubious that this could relate to the pressure sensor but I still ultimately get the same fault.
Hmm... so a bit more on this... I'm wondering if it's a wiring issue. Took the plug to the pump apart and reinserted and now, the fault doesn't come up unless I hit the switch to raise or lower the suspension. I've read on the disco3 forum that this might be due to wiring either behind the headlight or in the wheel arch depending on which MY my 57 plate car turns out to be. Anyone heard of this? |
I've had no luck with cheap, aftermarket compressors... |
Beginning to think it was the wrong call although Aerosus was recommended by someone (not here) as something half reliable.
Ideally, you want a diagnostic tool that can activate the exhaust valve, and check for correct voltage, and load test the wiring, before condemning the compressor
Thanks Mikey. Would a GAP IIDbe able to do that? You think it’s worth looking at anything else other than suspecting the compressor now?[/quote] |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
Buying good quality parts for the RRS goes a long way in eliminating future heartaches. |
In the spirit of providing updates on the final outcome of a problem. It was indeed the compressor at fault. Extensive diagnostics at a garage followed by swapping out the compressor for a genuine Hitachi solved the issue. Aerosus compressor being returned for a full refund! |
Thanks for the update. |
