Home > Technical > C1A13 after new compressor |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
From the manual:
2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat May 30 2020 5:44pm |
SomersetRRS Member Since: 18 Nov 2019 Location: Somerset Posts: 65 |
Thanks for that. My understanding is that the exhaust valve is integral to the compressor so (I know it's not a 100% solid assumption!) that shouldn't be the cause. That being the case, what's the easiest way to diagnose the exhaust silencer/pipe, reservoir pipes and gallery pipes? Thx. |
Sat May 30 2020 6:35pm |
So this is driving me a bit nuts... I decided to replace the centre reservoir block as well as I was a bit dubious that this could relate to the pressure sensor but I still ultimately get the same fault.
Sat Jun 13 2020 1:39pm |
Hmm... so a bit more on this... I'm wondering if it's a wiring issue. Took the plug to the pump apart and reinserted and now, the fault doesn't come up unless I hit the switch to raise or lower the suspension. I've read on the disco3 forum that this might be due to wiring either behind the headlight or in the wheel arch depending on which MY my 57 plate car turns out to be. Anyone heard of this? |
Sat Jun 13 2020 2:58pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
I've had no luck with cheap, aftermarket compressors... |
Sat Jun 13 2020 7:31pm |
Beginning to think it was the wrong call although Aerosus was recommended by someone (not here) as something half reliable.
Sat Jun 13 2020 7:43pm |
Ideally, you want a diagnostic tool that can activate the exhaust valve, and check for correct voltage, and load test the wiring, before condemning the compressor
Sat Jun 13 2020 8:14pm |
Thanks Mikey. Would a GAP IIDbe able to do that? You think it’s worth looking at anything else other than suspecting the compressor now?[/quote] |
Sat Jun 13 2020 9:37pm |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 |
Buying good quality parts for the RRS goes a long way in eliminating future heartaches. |
Sun Jun 14 2020 10:27am |
In the spirit of providing updates on the final outcome of a problem. It was indeed the compressor at fault. Extensive diagnostics at a garage followed by swapping out the compressor for a genuine Hitachi solved the issue. Aerosus compressor being returned for a full refund! |
Wed Jul 08 2020 2:57pm |
Thanks for the update. 2012 SDV6 - it's missing a couple of cylinders
Thu Jul 09 2020 8:10am |
