![]() | Home > Technical > Electronic parking brake will not releases. 2013 L494 |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
👆 That’s the L320 not L494,they work differently.Ive never seen this happen on a 494 but they work on the calliper so I’m guessing it could be a faulty calliper if the other one is releasing.You could try a diagnostic to wind the calliper back or try the manual way which is one here somewhere. Andy.
tonyp Member Since: 02 Aug 2011 Location: Middlesex Posts: 15 ![]() ![]() ![]() |
Thank you, I’ll do a search. The AA Guy plugged into the OBD and tried a reset but to no avail. He couldn’t get the cover off of the brake motor on the back of the calliper so gave up. I did peer over his shoulder at the diagrams on his tablet but I couldn’t see all of the detail. |
Ive never had the electronic part off on a RRS but I have on a DS & evoque & if you remove the electric part which is held on with a couple of allen key fittings you can wind it off that way with a socket on the end,but like I say im not 100% sure if the RRS is the same. Andy.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Taken from the RRS w/shop manual, basically as Andy said.
