Home > Technical > Electronic parking brake will not releases. 2013 L494
tonyp
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Hi, I’m a bit of a lurker so don’t post much.
However I’ve got a 2013 L494 and I’m currently sitting in a South London trading estate waiting to be recovered by the AA because my off side rear brake calliper won’t release following engaging it to park.
Is this a common problem and it there anything I can do?
Thank you.
Post #599364 Thu May 28 2020 7:33pm
erickwan
Malaysia
Post #599462 Mon Jun 01 2020 4:55am
Tyrefitter
👆 That’s the L320 not L494,they work differently.Ive never seen this happen on a 494 but they work on the calliper so I’m guessing it could be a faulty calliper if the other one is releasing.You could try a diagnostic to wind the calliper back or try the manual way which is one here somewhere. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #599463 Mon Jun 01 2020 5:06am
tonyp
erickwan wrote:
https://youtu.be/3h1rGmAsxq8
Thank you, I’ll do a search.
The AA Guy plugged into the OBD and tried a reset but to no avail.
He couldn’t get the cover off of the brake motor on the back of the calliper so gave up. I did peer over his shoulder at the diagrams on his tablet but I couldn’t see all of the detail.
Post #599471 Mon Jun 01 2020 8:32am
Tyrefitter
Ive never had the electronic part off on a RRS but I have on a DS & evoque & if you remove the electric part which is held on with a couple of allen key fittings you can wind it off that way with a socket on the end,but like I say im not 100% sure if the RRS is the same. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #599472 Mon Jun 01 2020 8:38am
Taken from the RRS w/shop manual, basically as Andy said.
Post #599474 Mon Jun 01 2020 8:55am
tonyp
Post #599500 Mon Jun 01 2020 6:09pm
