Home > Faults & Fixes > 2005 RRS 2.7 Suspension Fault
amgmaj
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Hi everyone
Can someone please give some advice on my friends 2005 RRS Suspension Fault I've hooked up to my IID Tool it came back with this code, he's only had the RRS few weeks now, bought of private seller.
The Suspension does not rise at all as you can see in the picture below
Is it safe drive as I advised him not to drive until fixed and guess what I had drop him off home 9 mile journey Shocked
C1131-92 (AF) Air supply - Component failure - performance or incorrect operation
Thank you
Post #599075 Mon May 18 2020 9:25pm
Stevepd
When you say doesn’t rise at all, is that all four corners?. Only because the rear looks decidedly down. If nothing rises then perhaps the common denominator is the compressor or or that area.
Somebody with more knowledge will be along Thumbs Up 2006 2.7 TDV6 HSE in Cairns Blue.
Post #599084 Tue May 19 2020 8:27am
amgmaj
Does not rise at all from any corner, the compressor comes on a few seconds but then stop once the warning light comes on...
Post #599086 Tue May 19 2020 10:11am
geoffsnook
After a very quick search on here Thumbs Up
https://www.disco3.co.uk/forum/suspension-...58164.html
Post #599087 Tue May 19 2020 11:27am
amgmaj
Could this pipe be the problem?
Can this be replaced easily and what is it called?
Post #599091 Tue May 19 2020 2:12pm
geoffsnook
If that's a hole i see then yes it will certainly not help search on here or disco3 to see hoe people have changed the air pipes and what with Thumbs Up
Post #599092 Tue May 19 2020 2:21pm
geoffsnook
Or even a quick search on the bay has kits too Thumbs Up
Post #599093 Tue May 19 2020 2:25pm
amgmaj
Thank you very @ geoffsnook
Will order them now Thumbs Up
Post #599113 Tue May 19 2020 7:15pm
jmadro
Spain 2007 Range Rover Sport TDV6 HSE Buckingham Blue
Muchas gracias geoffsnook
Post #620089 Sat Dec 18 2021 10:42am
