![]() | Home > Faults & Fixes > 2005 RRS 2.7 Suspension Fault |
When you say doesn’t rise at all, is that all four corners?. Only because the rear looks decidedly down. If nothing rises then perhaps the common denominator is the compressor or or that area.
amgmaj Member Since: 28 Nov 2017 Location: Nottingham Posts: 80 ![]() ![]() ![]() |
Does not rise at all from any corner, the compressor comes on a few seconds but then stop once the warning light comes on... |
After a very quick search on here |
Could this pipe be the problem?
If that's a hole i see then yes it will certainly not help search on here or disco3 to see hoe people have changed the air pipes and what with |
Or even a quick search on the bay has kits too |
Thank you very @ geoffsnook
jmadro Member Since: 21 Nov 2019 Location: sevilla Posts: 3 ![]() ![]() ![]() |
Muchas gracias geoffsnook |
