![]() | Home > Technical > TDV8 oil leak |
Try posting on full fat forum as the engine was used in them |
snpmc Member Since: 10 May 2020 Location: North West Posts: 2 ![]() ![]() |
Will do - thanks |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9029 ![]() ![]() ![]() |
I wonder if the vehicle has had a turbo failure in the past. That generally dumps oil in to the intercooler and the entire inlet tract. There's always some oil then present as the intercooler acts as a reservoir for oil that can then coat the inside of the pipes. If you look inside the top intercooler hoses, they would be coated with oil if this is the case. Or have you changed those already? It might be worth having a look even if you have - then if they're coated in oil you'll know it's coming from upstream of the plenum. 2012 SDV6 - it's missing a couple of cylinders
