Home > Technical > TDV8 oil leak
snpmc
TDV8 oil leak
Hi All,
I have a strange problem that I'm trying to track down on my '10 L320 TDV8, I've tried searching around but no luck...
There is a slow oil leak coming from the two rear plenum chamber hoses, it seems to be seeping around the circumference of the hoses, pooling on intake manifold and also leaking down the side of the engine.
So far, I've:
- Checked for damage on inlet manifold/plenum chamber
- Tried tightening and loosening the hose clamps
- Replaced all plenum chamber hoses
- Replaced the inlet manifold gasket
- Replaced the oil seperator
- Cleaned the breather-intake pipe
Other than maybe failing turbo seals (no other symptoms - smoke, oil usage, performance etc.), I'm out of ideas!
Anyone have any ideas/suggestions?
Thanks
Post #598778 Sun May 10 2020 7:18pm
DrRob
Try posting on full fat forum as the engine was used in them Thumbs Up Visitor from fullfatrr.com
Post #598779 Sun May 10 2020 7:37pm
snpmc
Will do - thanks Smile
Post #598780 Sun May 10 2020 7:42pm
I wonder if the vehicle has had a turbo failure in the past. That generally dumps oil in to the intercooler and the entire inlet tract. There's always some oil then present as the intercooler acts as a reservoir for oil that can then coat the inside of the pipes. If you look inside the top intercooler hoses, they would be coated with oil if this is the case. Or have you changed those already? It might be worth having a look even if you have - then if they're coated in oil you'll know it's coming from upstream of the plenum. 2012 SDV6 - it's missing a couple of cylinders
Post #598781 Sun May 10 2020 9:34pm
