Home > In Car Electronics > Multimedia Upgrade
tricey27
Multimedia Upgrade
Good Afternoon,
I have got a 2007 RRS TDV8. It has the factory head unit and factory sat nav installed. But doesnt have dvd player or tv. I want to have freeview tv, option to insert memory stick for films, reverse camera and dvd player. Ive briefly read about the GVIF units and want to know whats needed to install this equipment?
Can i use the antennas that are already installed in the rear windows?
Where can i get a reasonably priced GVIF from?
Will the reverse camera switch on automatically when i put it into reverse?
Will i switch over the various inputs through the usual screen with navigation, 4 x 4 info etc?
Many thanks in advance
Post #598530 Mon May 04 2020 2:37pm
Sound like a gvif is good for you.
Yes reverse camera is automatic
Yes you can play video thru front screen
Dunno how you can use a usb stick though
Best to use separate arials
Post #598546 Mon May 04 2020 6:31pm
geoffsnook
Aliexpress sell's them if you can wait and to change inputs there is a small button you fit it is small so can go quite close to screen Thumbs Up
Post #598547 Mon May 04 2020 6:43pm
Some of them connect to the private CAN and therefore the nav button will cycle thru the 3 inputs and nav
Post #598550 Mon May 04 2020 7:50pm
tricey27
Thanks very much! HAs anyone got a link to the AliExpress one please? Not in a major rush so worth saving some!
Is there anything else I will need?
Thansk
Post #598750 Sat May 09 2020 6:25pm
