Home > Technical > Suspension problems
John1311
Suspension problems
I was driving today and when going over some speed bumps I noticed that the suspension was making a fully and horrible squeaking noise going over them. When I stopped I was able to put the suspension up and down using the internal controls, but am concerned there's more of an issue here. I do have the IID tool.
Can anyone point me in the right diretion as to what I can look at - the fact the suspension goes up and down ok - im assuming its not a suspicions issue ?
Many thanks 2016 Range Rover Sport SDV6 autobiography (MY17)
2017 Range Rover Velar First Edition SDV6
2015 Range Rover Sport Autobiography 4.4
2012 Range Rover Sport SDV6 HSE Luxury Black
Post #596833 Sat Mar 21 2020 11:24pm
I might be inclined to try lubricating the anti roll bar bushes first with a silicone spray to see if that helps narrow it down, as I believe they are prone to wear.
Post #596834 Sat Mar 21 2020 11:42pm
With it parked up in normal height, rock the vehicle side-to-side. If you hear a loud squeak from the rear it's probably the hub bushes (the ones where the suspension arm meet the upright). They make a racket when they go. Had that problem before. 2012 SDV6 - it's missing a couple of cylinders
Post #596847 Sun Mar 22 2020 9:37am
