![]() | Home > Technical > Suspension problems |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
I might be inclined to try lubricating the anti roll bar bushes first with a silicone spray to see if that helps narrow it down, as I believe they are prone to wear.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9029 ![]() ![]() ![]() |
With it parked up in normal height, rock the vehicle side-to-side. If you hear a loud squeak from the rear it's probably the hub bushes (the ones where the suspension arm meet the upright). They make a racket when they go. Had that problem before. 2012 SDV6 - it's missing a couple of cylinders
