Home > Technical > Fault codes
Devon Z
Fault codes
I’m working my way through the fault codes recorded and down to 5 of which three are communication errors in the instruments section, lost communication with transfer case, ride level and parking assistance modules. Are these anything to worry about? Everything seems to work as it should I’ve not tried all the off road settings, hi low range engages without any error messages.
Steve Steve
1998 Volvo V70 R auto FWD, mothballed future project.
Post #596225 Sun Mar 08 2020 3:29pm
You can ignore U codes
Post #596227 Sun Mar 08 2020 3:43pm
Devon Z
Cheers Andy, the only other one of concern on the engine is cylinder 4 balance fuel trim at maximum, have researched this and possible things are air leak, fuel leak or dodgy injector? anything else I should look for?
Steve Steve
Post #596239 Sun Mar 08 2020 9:53pm
you should read the injector offsets (at idle) and post them up
Post #596251 Mon Mar 09 2020 12:04pm
Devon Z
UPDATE, this error has gone away Very Happy keep my fingers crossed it stays that way Wink
Steve Steve
Post #596737 Thu Mar 19 2020 8:28pm
Devon Z
This code has popped up again on my routine code check, cleared it and went for a long run yesterday and it’s not popped up again. I found out how to access live data on my Icarsoft code reader which is quite extensive these are the live offset readings on a cold engine and after about 15 minutes running.
I took a mid average as the figures were changing.
Cold
Injector
1 - 895
2 - 1275
3 - 930
4 - 987
5 - 860
6 - 1224
After 15 minutes running
1 - 990
2 - 1055
3 - 955
4 - 994
5 - 893
6 - 1213
From what I’ve read all are within tolerance only 2 and 6 being a tad high so I’m thinking nothing to worry about here? Steve
Post #607448 Sat Dec 12 2020 4:52pm
