Home > Technical > Fault codes |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
You can ignore U codes |
Sun Mar 08 2020 3:43pm |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 314 |
Cheers Andy, the only other one of concern on the engine is cylinder 4 balance fuel trim at maximum, have researched this and possible things are air leak, fuel leak or dodgy injector? anything else I should look for?
Sun Mar 08 2020 9:53pm |
you should read the injector offsets (at idle) and post them up |
Mon Mar 09 2020 12:04pm |
UPDATE, this error has gone away keep my fingers crossed it stays that way
Thu Mar 19 2020 8:28pm |
This code has popped up again on my routine code check, cleared it and went for a long run yesterday and it’s not popped up again. I found out how to access live data on my Icarsoft code reader which is quite extensive these are the live offset readings on a cold engine and after about 15 minutes running.
Sat Dec 12 2020 4:52pm |
