Home > General (L494) > "Service Required" in message display |
gtr_skyline Member Since: 28 Apr 2018 Location: St Albans Posts: 245 |
Hi - I and others have had this issue before - linked to oil dilution known issue and associated rapid countdown of the "next service"indicator - typically fixed under warranty by dealer with a new oil and filter change and some form of software update.
Mon Feb 24 2020 3:22pm |
crasher73 Member Since: 31 Jan 2020 Location: Peterborough Posts: 23 |
Thanks Prashan, very helpful. Is this problem considered urgent / priority? Clearly I won't leave it until September but would be useful to know if needs doing immediately.
Mon Feb 24 2020 3:31pm |
For me it was more of an annoyance - happened 3 times but seems to have stabilised of late. MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian |
Mon Feb 24 2020 4:51pm |
It’s a sign of DPF regenerations not being completed before you switch off the engine and these days JLR will tell you that you are not driving the car properly.......... so it’s your fault! Consequences of ignoring it - engine will go bang eventually as the oil is getting diluted with diesel. Unfortunately it is a common problem and not only with JLR products. Another unfortunate thing is JLR don’t fit a regen in progress lamp on the dash for you to know if a regen has started. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Feb 24 2020 5:34pm |
Cheers Tim in Scotland. On that basis you would think the DPF light would come on instead, at least that would be more relevant to the actual problem!!!
Mon Feb 24 2020 8:18pm |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 |
Hi Crasher73
Mon Feb 24 2020 9:28pm |
Cheers Ash3, appreciate the advice |
Tue Feb 25 2020 8:04am |
Ash is spot on - been doing more of this and car feels better for it too MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian |
Tue Feb 25 2020 10:25am |
As the service required warning is flagged then no amount of trying to do DPF regenerations will help, the car needs to have the engine oil flushed and filter changed as the %age diesel in the lube dilution has been reached. There is a software update for this but basically all it does is raise the amount of lube dilution the system detects before flagging up the service required warning. The regular high revs run will only help once the oil has been changed for new. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Feb 25 2020 1:04pm |
So I took the car to my local JLR specialist this morning. All plugged in, no faults found, no evidence of oil dilution, no dpf regen issues, oil / diesel fluid levels all where they should be, software all up to date etc etc.
Tue Feb 25 2020 1:27pm |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
That is good. But still worth cancelling the auto stop-start every time you start up. That will help to avoid the situation of the DPF never warming up on short journeys. Besides which, it is likely to make the emissions worse, not better. |
Wed Feb 26 2020 4:42pm |
samd Member Since: 21 Sep 2009 Location: Derbyshire Posts: 124 |
Just to add to that though is the issue of the 'service date' indicator being widely inaccurate even when no regens have failed. I mention in another thread where I had done 2 x 200 mile journeys, both non stop at over 60 mph average yet the service indicator changed by just about 1000 miles. |
Wed Feb 26 2020 4:54pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
There's a bit of stuff on YouTube about this stop/start nonsense. It seems that if they'd introduced it in the 60s and 70s it might have made a difference to cars then but with modern cars it seems like its more of a problem than a solution! Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Wed Feb 26 2020 9:51pm |
