Home > Faults & Fixes > Hdc system fault and new starter motor |
When was it last replaced(Battery) if you dont know then change it as these don't like low voltage |
Sat Feb 01 2020 6:50pm |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 314 |
I had similar HDC errors when I purchased mine, engine always span over well and stated but kept getting warning lights whilst cranking. Checked the battery voltage while cranking and it was about 9volts, new battery and all is good, still only 10.5volts but no errors and engine spins faster.
Mon Feb 17 2020 8:37pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
10.5V ? Sounds like the alternator is dead. 2012 SDV6 - it's missing a couple of cylinders
Mon Feb 17 2020 10:06pm |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
10.5V at rest, yes.. 10.5V during cranking, however, seems to be fairly normal - with a brand new battery and brand new Denso alternator (which isn't doing anything during cranking, really). Prior to battery change I also had 9V during cranking and the odd christmas-tree moment
Wed Feb 19 2020 9:32am |
Sorry, missed the "cranking" bit in the previous post. 2012 SDV6 - it's missing a couple of cylinders
Wed Feb 19 2020 10:26am |
Ah, that'd explain it
Wed Feb 19 2020 11:37am |
