![]() | Home > Wheels & Tyres > TPMS |
FrankH Member Since: 21 Mar 2017 Location: Crawley Posts: 23 ![]() ![]() ![]() |
The car will find them, I have two sets of wheels and the car just pairs with them all by itself. L494 2016 model. |
blueanchorinn Member Since: 11 Dec 2017 Location: Teignmouth Posts: 72 ![]() ![]() |
Thankyou |
If you still have your original wheels you could remove them & refit in new wheels,any one with a tyre machine can do them as you only need to break the outer bead,easy enough job. Andy.
Thanks for your reply but I’m being greedy and having two sets 😂. One for road and one for winter/playing |
Good idea,you can just purchase another set from that well known selling site just make sure the serial numbers correspond as ive known folk get them & not worked. Andy.
Serial numbers correspond?
could the tyre fitter have damaged a sensor fitting the tyres as the tyre has to be in a certain position on the tyre machine so they don’t get damaged. Andy.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
If it was just one sensor would the system not say which wheel position it was?
It’s unlikely he has damaged all four and it did work for a few minutes |
im guessing wrong sensors. Andy.
Bought from a long established indy who took the reg no so I’m hoping they are the right ones and why would they of worked for a while? |
If you have two sets of wheels, I realise it's a bit of work but is it worth re fitting your original wheels to see if the car is finds them ok. if it does it indicates sensors, if not then possibly the problem is the car system itself as the new ones worked originally for a short time and purely coincidence it played up after fitting the new wheels/sensors. Only a suggestion.
I’ll get SWMBO on it at the weekend. Thanks all |
