Home > Faults & Fixes > low fuel waring only below half a tank.
StephenRadford
Wales 2010 Range Rover Sport TDV8 HSE Java Black
Hi All,
I have searched through the forum to find a similar fuel empty fault, they all appear to be about the wiring connections, my low fuel fault appears when the fuel level drops below about half way, putting more fuel in and in all is ok and the low indicator goes out so I am ruling out bad connections.
The vehicle is a 2010 RRS TDV8 3.6, Could someone tell me where the sender units are located I understand there are two, how can I determine when one is at fault.
Many thanks.
Post #593002 Wed Jan 08 2020 12:20am
Brit Plumber
Normally the level sensors work on resistance so don’t rule out bad connections. Also, try disconnecting your battery for 20 minutes and reset everything, maybe it’s just lost calibration. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #593005 Wed Jan 08 2020 8:07am
StephenRadford
Thank you will try that first
Post #593028 Wed Jan 08 2020 5:29pm
StephenRadford
OK, it looks like I have a corroded joint some where, the sender unit came back on after doing an emergency stop then went off again when I put more fuel in. I disconnected the battery and left it for 20 mins reconnected it and the fuel gauge display worked for about 15 seconds then went to empty.
Could some please tell me the location of the sender units, I think they are under the rear seats, does this require the removal of the seats, any photos would really help.
Thanks in advance.
Post #593409 Fri Jan 17 2020 12:42pm
Oldandconfused
There is a thread on how to do this , give a search a go.
When I had mine done (too lazy to do it myself), from memory, there are actually 2 float/sender units in the fuel tank.You will have to drop the tank, best done when empty, and access them via a panel on top of the tank then remake the joints. Dirty smelly job if doing on the drive, hence why I paid for it to be done. To be on the safe side, I had new units installed as I intend to keep the car for the foreseeable future.
Post #593421 Fri Jan 17 2020 2:46pm
Google LTB00566v6 or alternatively there is a copy in "My Gallery" file No. 92 https://www.rrsport.co.uk/gallery/displayi...amp;pos=91 The senders are not under the seats, you have to lower the tank to remove them.
Post #593452 Fri Jan 17 2020 9:33pm
StephenRadford
Thank you guys you have been a great help, can you tell me what sort of cost I can expect to have it done?
Thanks.
Post #593541 Mon Jan 20 2020 2:21pm
Oldandconfused
When I had mine done (new gen LR senders x2, seal, clip and cover plus diagnostics) the indi I use charged me for 4 hours labour. If you just wanted someone to re-do the terminals that's your ball park.
The senders were £80 and £84 each plus VAT and I guess you may not need the cover and seal if they come off OK.
Post #593549 Mon Jan 20 2020 6:25pm
