![]() | Home > Faults & Fixes > low fuel waring only below half a tank. |
Normally the level sensors work on resistance so don’t rule out bad connections. Also, try disconnecting your battery for 20 minutes and reset everything, maybe it’s just lost calibration. 2019 5.0 SC SVA (Current)
StephenRadford Member Since: 10 Apr 2019 Location: Maesteg Posts: 4 ![]() ![]() ![]() |
Thank you will try that first |
OK, it looks like I have a corroded joint some where, the sender unit came back on after doing an emergency stop then went off again when I put more fuel in. I disconnected the battery and left it for 20 mins reconnected it and the fuel gauge display worked for about 15 seconds then went to empty.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
There is a thread on how to do this , give a search a go.
Google LTB00566v6 or alternatively there is a copy in "My Gallery" file No. 92 https://www.rrsport.co.uk/gallery/displayi...amp;pos=91 The senders are not under the seats, you have to lower the tank to remove them.
Thank you guys you have been a great help, can you tell me what sort of cost I can expect to have it done?
When I had mine done (new gen LR senders x2, seal, clip and cover plus diagnostics) the indi I use charged me for 4 hours labour. If you just wanted someone to re-do the terminals that's your ball park.
