Home > Faults & Fixes > TDV8 INLET MANIFOLD
rob cupples
TDV8 INLET MANIFOLD
does anyone have a guide on replacing TDV8 drivers side inlet manifold please? How much roughly do indy garages charge and how long does it take? Car went into restricted performance mode towing today, it looks like there is oil seeping from the drivers side inlet manifold. not sure yet if it is the manifold cracked or the gasket.
Post #592880 Sun Jan 05 2020 9:34pm
The workshop manual is here: http://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf
The inlet manifold isn't cheap - about £400 each side for genuine parts. https://www.advancedfactors.co.uk/inlet-ma...1735-c.asp 2012 SDV6 - it's missing a couple of cylinders
Post #592881 Sun Jan 05 2020 10:31pm
rob cupples
Thank you very much.
Post #592883 Sun Jan 05 2020 10:38pm
Disco_Mikey
Not the easiest of jobs, but certainly not the worst job I've ever done on a Sport Thumbs Up
As above though, parts aren't cheap
Post #592890 Mon Jan 06 2020 7:02am
rob cupples
thank you Mikey, I'll confirm it's that and get it booked into you. Got a few jobs now- rear ARC bar leak and possibly front, inlet manifold and needs gearbox flush.
Post #592901 Mon Jan 06 2020 12:50pm
rob cupples
disco mikey at MMP replaced manifold very efficiently with excellent service. Note that i did successfully expedient repair with Q weld which held up well, but worth replacing properly as likely to structurally fail under load such as towing.
Post #596971 Tue Mar 24 2020 9:41pm
