![]() | Home > Faults & Fixes > TDV8 INLET MANIFOLD |
rob cupples Member Since: 27 Jun 2018 Location: Stirling Posts: 30 ![]() ![]() ![]() |
does anyone have a guide on replacing TDV8 drivers side inlet manifold please? How much roughly do indy garages charge and how long does it take? Car went into restricted performance mode towing today, it looks like there is oil seeping from the drivers side inlet manifold. not sure yet if it is the manifold cracked or the gasket. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9029 ![]() ![]() ![]() |
The workshop manual is here: http://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf
Thank you very much. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4424 ![]() ![]() ![]() |
Not the easiest of jobs, but certainly not the worst job I've ever done on a Sport |
thank you Mikey, I'll confirm it's that and get it booked into you. Got a few jobs now- rear ARC bar leak and possibly front, inlet manifold and needs gearbox flush. |
disco mikey at MMP replaced manifold very efficiently with excellent service. Note that i did successfully expedient repair with Q weld which held up well, but worth replacing properly as likely to structurally fail under load such as towing. |
