![]() | Home > Technical > TDV8 3.6 RRS 2008 P0191-23 WONT START NO FUEL PRESSURE HELP |
You can change what it does so search maybe here or disco3
Not 100% sure on this but I know under the bonnet on my Disco3 there was a fuel cut off switch in case it rolled over I’m sure they knock out the fuel supply so may be worth looking at that to see if you have one and if it’s been activated as you have been messing with the system other than that maybe the pump has been dried by trying to jump it |
Failing that have a look on disco3 or one of the guys on here for a specialist near to you from here they may be able to help you more there are a few around you |
Tobias275 Member Since: 04 Jan 2020 Location: kent Posts: 12 ![]() ![]() ![]() |
thanks for the inertia pointer, found this thread https://www.rrsport.co.uk/forum/post441543.html |
