Home > General > Door sill protector plate RRS 2007 |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2793 |
I’ve removed - replaced a few in my time - for a new piece try the obvious sites first - fleabay etc & at worse you can source them through your local stealership. They don’t come as a pair so that’s handy in your situation The B pillar door trim is the only other part involved & only the lower part has to be pulled away slightly to allow the sill plastic to fit. Start by removing the damaged trim at the end nearest to the windscreen & pull up sharply. Top tip - beware the clips don’t fall into the holes that the new piece fits into. I’m sure I can find the instructions somewhere - pm me an email address to send to. It’s a 15 min job at most 16MY Estoril Blue SVR.............
Wed Jan 01 2020 8:06pm |
