Home > General > Door sill protector plate RRS 2007
Mark41
hi there,
the driver’s side aluminium door sill trip is pretty busted as per the attached pic.
Can anyone recommend a good place to get a replacement one from please? Also does anyone have any experience of removing this and replacing it please?
Thanks
Post #592610 Wed Jan 01 2020 7:50pm
PEACHY
I’ve removed - replaced a few in my time - for a new piece try the obvious sites first - fleabay etc & at worse you can source them through your local stealership. They don’t come as a pair so that’s handy in your situation Thumbs Up The B pillar door trim is the only other part involved & only the lower part has to be pulled away slightly to allow the sill plastic to fit. Start by removing the damaged trim at the end nearest to the windscreen & pull up sharply. Top tip - beware the clips don’t fall into the holes that the new piece fits into. I’m sure I can find the instructions somewhere - pm me an email address to send to. It’s a 15 min job at most Whistle 16MY Estoril Blue SVR.............
Post #592612 Wed Jan 01 2020 8:06pm
