Home > Technical > mirrors during revesing |
sportman Member Since: 25 Jul 2005 Location: UAE Posts: 550 |
Hello
Sun Feb 25 2007 6:29am |
Robbi Member Since: 14 Jun 2005 Location: Channel Islands, Guernsey Posts: 130 |
Agree...it's totally crazy to dip so much. Pity they didn't allow a way to set how much the mirrors dip or even 2 settings via a switch...would have been more useful. Only really useful they lining up between two parking lines. Not a problem in Dubai I expect since, if my memory is good, they are much wider than UK parking bays! Rob
Sun Feb 25 2007 10:09am |
King of the Road Member Since: 30 Oct 2006 Location: Geneva Posts: 11 |
You can turn the mirror dip on or off and you can also adjust the mirror dip itself. It's in the manual... |
Sun Feb 25 2007 10:31am |
Reverse mirror dipping Vehicles with driver’s seat memory have a pre-stored function, which causes the door mirrors to dip whenever reverse gear is selected, giving the driver a view of the kerbside. When this feature is first turned on, the mirrors will dip to a pre-set amount. The degree of dipping can be programmed using the following sequence: 1 Insert the starter key and turn it to position ll. 2 Adjust the seat and the exterior mirrors to the correct position and perform a memory-store routine. 3 Select reverse gear - the mirrors will dip to a pre-set level. 4 Adjust the mirrors to the required dipped position. 5 Perform a memory-store sequence. 6 DOOR MIRROR DIP STORED will appear on the message centre. 7 A single chime will sound from the instrument pack. As has been said, read the manual... Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Sun Feb 25 2007 11:12am |
thanks Bobby 2007 Range Rover Sport Supercharged, Buckingham Blue, Ivory converted to HST Silver
Sun Feb 25 2007 5:35pm |
aam1234 Member Since: 08 Aug 2006 Location: Somewhere out there Posts: 450 |
You can turn it on/off by using the "i" button on the left lever. There are many options there too. |
Sun Feb 25 2007 6:02pm |
