Home > Technical > mirrors during revesing
sportman
United Arab Emirates 2006 Range Rover Sport Supercharged Buckingham Blue
Hello
these mirrors are flipping or moving down during reversing, driving me crazy, any way to disable that feature 2007 Range Rover Sport Supercharged, Buckingham Blue, Ivory converted to HST Silver
SOLD-V8 Defender 90
Post #86944 Sun Feb 25 2007 6:29am
Bobby
Re: mirrors during revesing
sportman wrote:
Hello
Yes, its a configurable feature and you can disable it yourself.
Read your Owner's Manual to disable Reverse Mirror Dip. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #86946 Sun Feb 25 2007 8:23am
Robbi
Guernsey 2007 Range Rover Sport TDV8 HSE Rimini Red
Agree...it's totally crazy to dip so much. Pity they didn't allow a way to set how much the mirrors dip or even 2 settings via a switch...would have been more useful. Only really useful they lining up between two parking lines. Not a problem in Dubai I expect since, if my memory is good, they are much wider than UK parking bays! Rob
*Gone - HSE TDV8 Rimini Red + Tasmod sill plates
Post #86967 Sun Feb 25 2007 10:09am
King of the Road
You can turn the mirror dip on or off and you can also adjust the mirror dip itself. It's in the manual... Whistle
Post #86968 Sun Feb 25 2007 10:31am
Bobby
Robbi wrote:
... Pity they didn't allow a way to set how much the mirrors dip... !
Reverse mirror dipping
Vehicles with driver’s seat memory have a pre-stored function, which causes the door mirrors to dip whenever reverse gear is selected, giving the driver a view of the kerbside.
When this feature is first turned on, the mirrors will dip to a pre-set amount.
The degree of dipping can be programmed using the following sequence:
1 Insert the starter key and turn it to position ll.
2 Adjust the seat and the exterior mirrors to the correct position and perform a memory-store routine.
3 Select reverse gear - the mirrors will dip to a pre-set level.
4 Adjust the mirrors to the required dipped position.
5 Perform a memory-store sequence.
6 DOOR MIRROR DIP STORED will appear on the message centre.
7 A single chime will sound from the instrument pack.
As has been said, read the manual... Smile Malaysia Boleh!
Post #86972 Sun Feb 25 2007 11:12am
sportman
thanks Bobby Thumbs Up 2007 Range Rover Sport Supercharged, Buckingham Blue, Ivory converted to HST Silver
SOLD-V8 Defender 90
Post #87049 Sun Feb 25 2007 5:35pm
aam1234
2007 Range Rover Sport Supercharged Rimini Red
You can turn it on/off by using the "i" button on the left lever. There are many options there too.
Post #87060 Sun Feb 25 2007 6:02pm
