Home > In Car Electronics > Retrofit OEM DAB+ module in RRS MY 2011
MM4747
Spain 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
Anyone retrofitted an LR original DAB unit to a 2011 RRS?
Is it a plug and play option when adding/replacing with a second hand Land Rover original DAB unit?
I know nothing about the internals of my current system and can't find any schematics anywhere to help me.
Currently I plug in my iPhone to access DAB using the TuneIn App which is not bad but a bit fiddly to use on the move.
Many thanks for any assistance. RRS 2011 TDV6 HSE Limited Edition, Fuji. Previous owned: Vogue 3.5, Vogue 3.9, Vogue 4.0, Disco2, Disco3
Post #592445 Sat Dec 28 2019 2:28pm
Brit Plumber
LR has a kit to upgrade from DAB to DAB+ as it required extra wiring. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #592491 Sun Dec 29 2019 9:56am
MM4747
Thanks Brit Plumber,
I currently don't have DAB in my RRS.
I was hoping to fit a DAB unit puchased on Ebay and exchange it with the unit already fitted.
Cheers RRS 2011 TDV6 HSE Limited Edition, Fuji. Previous owned: Vogue 3.5, Vogue 3.9, Vogue 4.0, Disco2, Disco3
Post #593075 Thu Jan 09 2020 10:06pm
djpgowrie
MM4747 did you ever get to the bottom on this? I too am looking to install a standard DAB module from ebay and can't find references for where to install the module or how to remove any trims if required.
Post #600654 Mon Jun 22 2020 4:39pm
Dave B
I looked into doing this on my Disco, and upgrading the DAB in my RRS to DAB+.
Ended up buying a Kinetic Digitizor from dabonwheels and a powered DAB sharkfin antenna from elsewhere for the Disco and am well pleased with the result.
For the RRS I'll just get the Digitizor as the antenna is already there.
Dave 2010 3.6 TDV8 HSE (Gone)
Post #600656 Mon Jun 22 2020 5:11pm
hairy
United Kingdom 2009 Range Rover Sport TDV8 HSE Zambezi Silver
Ive don eit, fitted a pioneer unit to my RRS, plays cds/dvds/I also fitted reverse camera while i was at it, all very easy, kept original Landrover satnav/steering wheel controls etc.
Post #600657 Mon Jun 22 2020 5:33pm
djpgowrie
Good to hear guys!
Though I'd rather get a factory RR unit off ebay for £40 and keep OEM head unit if possible. Do either of you have advice on removing the boot lining on the sides? I can't for the life of me find a vid or pics of clips or however it's fixed.
I know the antenna is in the rear quarter window, I have a shark fin, and the module is apparently behind the boots rear quarter panel lining.
Post #600674 Tue Jun 23 2020 6:55am
Even the instructions in the workshop manual are a bit vague, however if you view these instructions in "my gallery" and click on them they should be more legible, I also think you will find Band L of the Dab antenna is in the shark fin, Band III is in the nearside rear quarter window, although I will admit haven't a clue as to the difference, frequencies I guess.
Post #600678 Tue Jun 23 2020 8:14am
hairy
djpgowrie wrote:
Good to hear guys!
no need to remove rear panels if you upgrade to a double din unit and keep your head(satnav) all working as it does normally. DAB aerial is fitted just beside A pillar at front of windscreen, use original aerial for radio, I tapped into the original mic in the roof and used that so no external mic either, comes with USB connector which i fitted in the ashtray (never use it) so when closed no cable, I also fitted a reversing camera at the same time as all of the above Smile
Post #600697 Tue Jun 23 2020 7:58pm
Brit Plumber
A lot of mods will depend on the model year and spec of the system. 2019 5.0 SC SVA (Current)
Post #600701 Tue Jun 23 2020 8:51pm
[quote="hairy"]
djpgowrie wrote:
Good to hear guys!
I think he may have a Facelift variant, and have never seen a double din unit conversion advertised for the facelift, although to be fair haven't actualy been looking for one.
Post #600704 Tue Jun 23 2020 10:25pm
djpgowrie
Yeah I've got 2010 face-lift version (I think) haha! There's been some mods to it from previous owner like 2012 tailgate. Think it's got autobiography bumpers too but don't know if thats standard on this spec?
Anyway.......
Thanks for the pics Col, I'll check them out and let you know!
Post #600738 Wed Jun 24 2020 3:18pm
When you remove the panel just be a little bit careful when removing the front part which goes down the wheel arch by the seat rather than just yank on it, as this is only sort of plastic spot welded to the larger part and can separate although not a major problem if they do.
Cheer
Post #600771 Wed Jun 24 2020 10:29pm
