![]() | Home > In Car Electronics > Retrofit OEM DAB+ module in RRS MY 2011 |
LR has a kit to upgrade from DAB to DAB+ as it required extra wiring. 2019 5.0 SC SVA (Current)
MM4747 Member Since: 22 Sep 2014 Location: Javea/Xabia Posts: 14 ![]() ![]() ![]() |
Thanks Brit Plumber,
djpgowrie Member Since: 04 Jun 2020 Location: Manchester Posts: 43 ![]() ![]() ![]() |
MM4747 did you ever get to the bottom on this? I too am looking to install a standard DAB module from ebay and can't find references for where to install the module or how to remove any trims if required. |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 432 ![]() ![]() ![]() |
I looked into doing this on my Disco, and upgrading the DAB in my RRS to DAB+.
hairy Member Since: 02 Feb 2020 Location: aberdeen Posts: 31 ![]() ![]() ![]() |
Ive don eit, fitted a pioneer unit to my RRS, plays cds/dvds/I also fitted reverse camera while i was at it, all very easy, kept original Landrover satnav/steering wheel controls etc. |
Good to hear guys!
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Even the instructions in the workshop manual are a bit vague, however if you view these instructions in "my gallery" and click on them they should be more legible, I also think you will find Band L of the Dab antenna is in the shark fin, Band III is in the nearside rear quarter window, although I will admit haven't a clue as to the difference, frequencies I guess.
no need to remove rear panels if you upgrade to a double din unit and keep your head(satnav) all working as it does normally. DAB aerial is fitted just beside A pillar at front of windscreen, use original aerial for radio, I tapped into the original mic in the roof and used that so no external mic either, comes with USB connector which i fitted in the ashtray (never use it) so when closed no cable, I also fitted a reversing camera at the same time as all of the above ![]() |
A lot of mods will depend on the model year and spec of the system. 2019 5.0 SC SVA (Current)
[quote="hairy"]
I think he may have a Facelift variant, and have never seen a double din unit conversion advertised for the facelift, although to be fair haven't actualy been looking for one. Cheers Col |
Yeah I've got 2010 face-lift version (I think) haha! There's been some mods to it from previous owner like 2012 tailgate. Think it's got autobiography bumpers too but don't know if thats standard on this spec?
When you remove the panel just be a little bit careful when removing the front part which goes down the wheel arch by the seat rather than just yank on it, as this is only sort of plastic spot welded to the larger part and can separate although not a major problem if they do.
